Pass a variable to a path inside a loop
1590
09-06-2017 09:07 AM
DuminduJayasekera
I need to pass year to the path inside a for loop in python script.
years = [2010,2011,2012]
months = [9]
for year in years:
   for month in months:
     arcpy.env.workspace = r'H:\Test_ONLY\prism_800m_'+ year[:4]
     scratch = r'H:\Test_ONLY\scratch'
     if year % 4 > 0 and month == 9:
          fmaskrasters1 = fmaskrasters[243:249]
          fmaskrasters2 = fmaskrasters[249:255]
          fmaskrasters3 = fmaskrasters[255:261]
          fmaskrasters4 = fmaskrasters[261:267]
          fmaskrasters5 = fmaskrasters[267:273]
     else:
          print("Not configured in the script!")
I want to change r'H:\Test_ONLY\prism_800m_2010 each time for the months from Sep.
How can I achieve this by modifying the above code. I think I am not doing something right in arcpy.env.workspace = r'H:\Test_ONLY\prism_800m_'+ year[:4]
can somebody help me to correct this?
Thanks in advance.
Tags (1)
JakeSkinner
Esri Esteemed Contributor
Hi Dimindu,
Try the following:
arcpy.env.workspace = r'H:\Test_ONLY\prism_800m_'+ str(year)
JakeSkinner
Hi Dimindu,
Try the following:
DuminduJayasekera
Thanks a lot. It worked.
RebeccaStrauch__GISP
Don't forget to mark Jake's answer correct so the thread can be closed. Thanks.
