ArcGIS Pro using license with arcpy with Pro closed
2279
09-06-2017 01:59 PM
jameshickey
As the title suggests, is it possible to use your ArcGIS Pro license to run an automated script if ArcGIS Pro is closed on the machine you run the script on?
Such as every night at midnight overwrite some tables in a gdb.
DanPatterson_Retired
As a Scheduled Task .... I think is what you are referring to
deleted-user-liuO8zXUrBPr
Does one have to take Pro Named user license offline to run a scheduled task?
MichaelVolz
Esteemed Contributor
But if 1 of the following conditions is not met you will receive a run-time error:
As such it does not appear that this question has been answered.
