How to split parcel gdb file into grid
1215
09-03-2017 08:19 PM
BrianChapman2
I have one large gdb file I need to split into a grid (imported from another shape file).  Is there a way to do this?
JayantaPoddar
If you have an ArcGIS for Desktop Standard or ArcGIS for Desktop Advanced license, you can use the Split Polygons command to split polygons (Parcel) by overlapping features (grid).
Think Location
BrianChapman2
Thank you, I will try that. Appreciate your help.
DanPatterson_Retired
If you have an advanced license, you can also use Split... from the analysis toolset... you can create a Fishnet first if you need to create the tiles for splitting as well
