Is it possible to update the source of a layer within an mxd using arcpy mapping?
1419
09-04-2017 10:02 AM
RichardGeoghegan2
I have an mxd which contains a layer (in shapefile format).
I wish to update the path of the shapefile to the path of another shapefile by using a stand alone script.
Is this possible?
I have used arcpy.mapping.AddLayer to find my layer.
I wonder if I can now use .replaceDataSource to update the source of the layer in the mxd?
DanPatterson_Retired
Did you try it and it didn't work?
Not sure what the problem is unless you don't have the files anymore to try.
Look at UpdataLayer which essentially does a remove and add
replaceDatasource etc
RebeccaStrauch__GISP
You can also check to see if any of the tools in my addin will work.  I mainly works on broken links but can be adapted to work with any.
/blogs/myAlaskaGIS/2015/08/31/python-addin-for-data-inventory-and-broken-link-repair?sr=search&searc...
