Feature Service Layer Not Appearing in AGOL
969
09-03-2017 03:09 AM
JillThornton1
A Feature Service layer I created from Desktop and shared for AGOL is not appearing in the Map Viewer online. In the Item Details, the thumbnail shows the layer and symbology as a preview, but when I add to the map, it doesn't draw. It does appear in the table of contents on the left, and all the functions for editing it appear to be operating normally...just doesn't draw.
XanderBakker
Esri Esteemed Contributor
I had this once, which was related to errors in some geometries of the featureclass that I published. Run Repair Geometry—Help | ArcGIS Desktop on a copy of you data to see if there are any problems in the data and republish.
JayantaPoddar
If Xander's suggestion doesn't work out, you need to ensure that the data's extent and its coordinate system are correctly defined.
A common mistake we make is defining a Projected Coordinate System for the data whose extent should have been defined in Decimal Degrees.
You could verify the data by overlaying it on top of an Esri Basemap in ArcMap.
Think Location
