why doesnt 'MyWidget' show up?
1445
08-31-2017 11:27 AM
AndrewDavis5
I've been using Web AppBuilder (developer) locally on my workstation.  I am using my AGOL machine url as my machine name, and the ClientId I got from my application I created using the Developer page.
I have been working through a tutorial
Create a custom in-panel widget—Web AppBuilder for ArcGIS (Developer Edition) | ArcGIS for Developer...
I got to step 10 after doing a little bit of change to my page on
http://myAGOLmachine:3344/webappviewer/?config=sample-configs/config-demo.json  I can see the widget there
but when I try to edit and add the 'MyWidget' to my
http://myAGOLmachine:3344/webappbuilder/?id=3  application I do not see the widget as an option to add.
Any advice is welcome.
Andy##
RobertScheitlin__GISP
Andy,
   If you left you widget inside the "samplewidgets" folder, that is your issue. The samplewidgets is excluded from the WAB Builder apps widget list.
Andy,
AndrewDavis5
Robert, good morning..  Thanks...that works nicely.
