restoredatastore syntax
4044
8
08-29-2017 04:45 PM
MarshallRobinson
I'm attempting to restore my datastore using the restoredatastore command line utility and I need some help with getting the right syntax for the command I'm writing.
When I run it I keep getting a "failed to generate token" as if my password is wrong, but I think the real issue is how I'm writing the url parameter. Does anyone have experience running this utility successfully?
Tags (1)
RebeccaStrauch__GISP
I don't know the answer, but it might help if you show the syntax you are using (replace an user/pass data, of course)
MarshallRobinson
Forgot to add that on my first post...my bad. Here it is:
restoredatastore --store relational --target db_7gyct-20170824055959004.backup --source-loc \\localhost\DataStoreBackup\relational\dbbackup\db_7gyct-20170824055959004 --data-dir C:\Users\Administrator\Documents\DataStoreRestore --server-url http://<servername>/server --server-admin *** --server-password ****
I've tried multiple variations of the --server-url parameter and get the same error.
again, I don't know for sure, but I would try
https://<servername>:6443/..       or http://<servername>:6080/..    or the equivalent for Portal (since that is probably what this is related to??).
PeterKing
I had the same issue today but found that it was because I was writing the "--server-admin" syntax as "--server-admin <domain/username>"
The restore tool worked when written as "--server-admin <username>"
MarshallRobinson
Thanks, but I couldn't get that to work either. Not sure what's going on. Do you know if there are more detailed error logs for this kind of issue?
I do not since I haven't used it.  I'm assuming you already looked thru the help?
Recover a data store—Portal for ArcGIS (10.5.x) | ArcGIS Enterprise
If you have and still have issues, might be worth a call/chat with tech support.
MarshallRobinson
Yeah, I guess it's time for tech support. Have you ever had to use the recovery tool? I've followed the documentation line-by-line and it doesn't work for me. Even when trying to use the most basic recovery parameters.
I have not.  We are still testing Portal.
