Query Widget 2.5
2099
10
08-28-2017 11:19 AM
GeorgeKatsambas
I am creating a group queries on different map services, the query works, the result is added to the map but it does not draw, I am using WAB 2.5. Any ideas?
RobertScheitlin__GISP
No that would mean that you should have two json files in the configs\Query\ folder.
GeorgeKatsambas
Since noone has answered is there another thread that this question may be posted in?https://community.esri.com/groups/web-app-builder-custom-widgets
George,
   There is just not enough info for anyone to provide help on this. All the errors I see in the console are from the API and not the actual Query Widget. What does your config json for the query widget look like for that layer?
GeorgeKatsambas
"hideLayersAfterWidgetClosed": true,
"queries": []
George,
   Well if that is your config_Query.json then you have not layers setup to be queried...
GeorgeKatsambas
I am choosing a map service, I am getting a result in a popup window, the query layer is added to the map it just does not display. The config.json is not changing?
George,
   Are you grabbing the right json file then? When you make configuration setting changes the json will be saved in the apps configs folder and then the widget name i.e.
configs\Query\config_Query.json (after you save).
GeorgeKatsambas
Yes all the configs file showing the same, the query config I grabbed is from the apps config folder
George,
   You may want to contact esri tech support then as your error and the fact that it is not writing a proper config file seems like a bug.
GeorgeKatsambas
Adding the query widget twice would that overwrite the config file? I added 2 query widgets for ease to the users.
