Calculate Correlation and Pearson between two sets of rasters
24177
11
08-21-2017 11:33 AM
ShouvikJha
Branched from: https://community.esri.com/thread/199323-re-trend-analysis-through-time-series-of-raster-data
Hi Xander Bakker‌,  Some modification I want to do in correlation script.
I Would like to calculate the P value as a raster in addition to correlation raster.
Using scipy library, I just ran one script to obtain the correlation and P value. Script is attached below
import numpy as np
from scipy.stats import pearsonr
x = np.array([ 58295.62187335,  45420.95483714,   3398.64920064,    977.22166306, 5515.32801851,  14184.57621022,  16027.2803392 ,  15313.01865824, 6443.2448182 ])
y = np.array([ 143547.79123381,   22996.69597427,    2591.56411049, 661.93115277,    8826.96549102,   17735.13549851, 11629.13003263,   14438.33177173,    6997.89334741])
r,p = pearsonr(x,y)
print "r", r
print "p", p
Output
Returns:
r : 0.831087956392
Pearson’s correlation coefficient
p-value : 0.00550539621039
2-tailed p-value
So instead of Numpy, can we use here Numpy and Scipy both library to get the addition p value or in the existing  script can we add this function to obtain the p Value as a raster
Thanks & regards
Shouvik Jha
XanderBakker
Esri Esteemed Contributor
Hi shouvik jha , I branched this question to give it more visibility and to avoid letting the post grow too much and contain multiple questions.
Basically, what I would do is define a second numpy that will hold the pearson value. This is what it would look like:
  • line 11 defined the pearson output raster path and name
  • line 35 creates the pearson numpy array
  • line 57 and 58 will call the pearson function and store the result in the numpy array
  • line 76 to 80 will store the output pearson raster
  • line 103 to 112 contains the function that calculated the pearson value
def main():
    print "load modules..."
    import arcpy
    import numpy as np
    template1 = r'C:\GeoNet\Correlation\Parameter1\r{0}_NPP.TIF'
    template2 = r'C:\GeoNet\Correlation\Parameter2\r{0}_WUE.TIF'
    nodata = -3.4028235e+38
    out_ras_corr = r'C:\GeoNet\Correlation\Pearson\correlation.TIF'
    out_ras_pear = r'C:\GeoNet\Correlation\Pearson\pearson.TIF'
    print "create nested numpy array list..."
    lst_np_ras = []
    for i in range(1, 14):
        ras_path1 = template1.format("%03d" % (i,))
        print " - ", ras_path1
        ras_np1 = arcpy.RasterToNumPyArray(ras_path1)
        ras_path2 = template2.format("%03d" % (i,))
        print " - ", ras_path2
        ras_np2 = arcpy.RasterToNumPyArray(ras_path2)
        lst_np_ras.append([ras_np1, ras_np2])
    print "read props numpy raster..."
    ras_np = lst_np_ras[0][0]  # take first numpy array from list
    rows = ras_np.shape[0]
    cols = ras_np.shape[1]
    print " - rows:", rows
    print " - cols:", cols
    print "create output numpy array..."
    ras_path = template1.format("%03d" % (1,))
    raster = arcpy.Raster(ras_path)
    ras_np_res_corr = np.ndarray((rows, cols))
    ras_np_res_pear = np.ndarray((rows, cols))
    print " - out rows:", ras_np_res_corr.shape[0]
    print " - out cols:", ras_np_res_corr.shape[1]
    print "loop through pixels..."
    pix_cnt = 0
    for row in range(rows):
        for col in range(cols):
            pix_cnt += 1
            if pix_cnt % 5000 == 0:
                print " - row:", row, "  col:", col, "  pixel:", pix_cnt
            lst_vals1 = []
            lst_vals2 = []
            try:
                for lst_pars in lst_np_ras:
                    lst_vals1.append(lst_pars[0][row, col])
                    lst_vals2.append(lst_pars[1][row, col])
                lst_vals1 = ReplaceNoData(lst_vals1, nodata)
                lst_vals2 = ReplaceNoData(lst_vals2, nodata)
                # perform calculation on list
                correlation = CalculateCorrelation(lst_vals1, lst_vals2, nodata)
                ras_np_res_corr[row, col] = correlation
                pearson = CalculatePearsons(lst_vals1, lst_vals2, nodata)
                ras_np_res_pear[row, col] = pearson
            except Exception as e:
                print "ERR:", e
                print " - lst_vals1:", lst_vals1
                print " - lst_vals2:", lst_vals2
    pnt = arcpy.Point(raster.extent.XMin, raster.extent.YMin) #  - raster.meanCellHeight
    xcellsize = raster.meanCellWidth
    ycellsize = raster.meanCellHeight
    print "Write output rasters..."
    print " - ", out_ras_corr
    ras_res_corr = arcpy.NumPyArrayToRaster(ras_np_res_corr, lower_left_corner=pnt, x_cell_size=xcellsize,
                                 y_cell_size=ycellsize, value_to_nodata=nodata)
    ras_res_corr.save(out_ras_corr)
    arcpy.DefineProjection_management(in_dataset=out_ras_corr, coor_system="GEOGCS['GCS_WGS_1984',DATUM['D_WGS_1984',SPHEROID['WGS_1984',6378137.0,298.257223563]],PRIMEM['Greenwich',0.0],UNIT['Degree',0.0174532925199433]]")
    print " - ", out_ras_pear
    ras_res_pear = arcpy.NumPyArrayToRaster(ras_np_res_pear, lower_left_corner=pnt, x_cell_size=xcellsize,
    ras_res_pear.save(out_ras_pear)
    arcpy.DefineProjection_management(in_dataset=out_ras_pear, coor_system="GEOGCS['GCS_WGS_1984',DATUM['D_WGS_1984',SPHEROID['WGS_1984',6378137.0,298.257223563]],PRIMEM['Greenwich',0.0],UNIT['Degree',0.0174532925199433]]")
def CalculateCorrelation(a, b, nodata):
    import numpy
    try:
        coef = numpy.corrcoef(a,b)
        return coef[0][1]
    except:
        return nodata
def ReplaceNoData(lst, nodata):
    res = []
    for a in lst:
        if a < nodata / 2.0:
            res.append(None)
        else:
            res.append(a)
    return res
def CalculatePearsons(a, b, nodata):
    import numpy
    try:
        x = np.array(a)
        y = np.array(b)
        r, p = pearsonr(a, y)
        return p
    except:
        return nodata
if __name__ == '__main__':
    main()
At this moment I am getting a "RuntimeError: ERROR 999998: Unexpected Error" on line 73 when saving the output correlation raster. I will look into that and see what the problem is. You could try and run the code to see if it works on your system.
XanderBakker
Hi shouvik jha , just like the original code has the function CalculateCorrelation:
    import numpy
    try:
        return coef[0][1]
    except:
        return nodata
... you could implement one that calculates p:
    import numpy
    try:
        x = np.array(a)
        y = np.array(b)
        return p
    except:
        return nodata
Include the function and on line 62 change:
by (although the "correlation" will be the p value) :
correlation = CalculatePearsons(lst_vals1, lst_vals2, nodata)
I did not try the code though.
ShouvikJha
Hi Xander Bakker‌, Thank you for the suggestion.
I trying to modify the code as you suggested but i don't understand, where I have to call the p Value raster.
From our earlier script, We got the output only Correlation raster, but this time I want Correlation raster as well as P value raster.
Snap from our earlier script on Input and output:
import numpy as np
    template1 = r'D:\Correlation\Parameter1\r{0}_NPP.TIF'
    template2 = r'D:\Correlation\Parameter2\r{0}_WUE.TIF'
    out_ras_Corr = r'D:\Correlation\correlation.TIF' # Already exist in our script
    out_ras_p    = r'D:\Correlation\Significance.TIF' # this one i want to add
ShouvikJha
Hi Xander Bakker‌, I am facing same problem here also.
we eagerly await your response
Thanks & regards
Shouvik Jha
XanderBakker
def main():
    import arcpy
    import numpy as np
    lst_np_ras = []
    pix_cnt = 0
            pix_cnt += 1
            lst_vals1 = []
            lst_vals2 = []
            try:
                print "ERR:", e
    import numpy
    try:
        return coef[0][1]
    except:
        return nodata
    res = []
    for a in lst:
            res.append(None)
        else:
            res.append(a)
    return res
    import numpy
    try:
        x = np.array(a)
        y = np.array(b)
        return p
    except:
        return nodata
    main()
ShouvikJha
Hi Xander Bakker Thank you very much for such wonderful script.
However I am running the script on my system and will inform you shortly.
XanderBakker
Í just noted an error: line 104 should be:
import numpy as np
XanderBakker
I also changed lines 73 and 79 into :
    arcpy.CopyRaster_management(ras_res_corr, out_ras_corr)
and
    arcpy.CopyRaster_management(ras_res_pear, out_ras_pear)
On a small subset it worked without problems. I did not check the resulting Pearson value though...
ShouvikJha
Hi xander_bakker‌, Thank you very much for your such great cooperation. We are really very thankful for such wonderful and useful script from you.
The updated script is running perfectly and produced the exact result.
Thanks & regards
Shouvik Jha
XanderBakker
Glad to hear that the code worked. Could you mark the question answered?
Kind regards, Xander
