How to delete / remove a personal reference from the list of "Style References"?
Solved! Go to Solution.
Thanks much Adrian! After locating the file per paths you provided me, I renamed the original for safety, then created new symbols / “Save as” to create my new default Style! Excellent!
Byron,
You can probably find it in your program files, here:
C:\Program Files (x86)\ArcGIS\Desktop10.3\Styles
(or whatever version number you are using)
And then delete it out. Unless it got saved to your roaming folder, it would be found here:
C:\Users\[your userame]\AppData\Roaming\ESRI\Desktop10.3\ArcMap
Byron,
I'm glad this was helpful. If this answered your question, please mark the response as correct.
Adrian
