Cannot open (txt) file in second loop
1009
08-24-2017 04:36 AM
Nicole_Ueberschär
It's me again with lots of cruises/campaigns, points and txt files but now I have additionally polygons to create.
This is my main script:
def main():
    # Step 1: find the source files to process
    list_of_files=[]
    list_of_files = FindFiles(location_for_tables)
    # Step2: prozess each file to data for points
    for each_file in list_of_files:
        # create and save sub tables
        store_table(each_file)
    # Step3: prozess each file to create a point in kivupoints
    list_of_tables = FindFiles(DirOutTables)
    for each_table in list_of_tables:
        # create and store the point
        tview = CreateTableView(DirOutTables, each_table)
        pointInfo = ReadPointInfo(tview)
        uid = LoadPointInfoToClass(pointInfo)
    # Step4: select points per campaign and create a polygon
    for each_campaign in list_of_files:
        arcpy.AddMessage(list_of_files)
        CreatePolygonFromCampaign(each_campaign)‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍
In Step2 and Step4 I am using the same files. But because I have to use the result from Step3 in Step4 I can't use the same for loop for Step2 and Step4. In both functions store_table(each_file) and CreatePolygonFromCampaign(each_campaign) I ask for the uniqueValues of one attribute of the current file. While this works perfectly with profile_nrs=unique_values(table, "Station") in the store_table(each_file) function (table receives the value from each_file), in the CreatePolygonFromCampaign(each_campaign) it tells me the correct file name but stops the script with the error message "cannot open 'KivuWatt_151120_Near-plant_CTM257 (2).txt'" (which is the correct txt file) while trying to retrieve the unique values for the Cruise attribute. I also tried other attributes and other files but with the same result.
I wonder if the file is somehow "blocked" by the first loop or the first uniqueValues() method since it's using a SearchCursor. But it's using a "with arcpy.da.SearchCursor(table, [field]) as cursor" so I would assume it should release/delete the cursors afterwards again...
Any help on this will be highly appreciated.
I think I provided all necessary information and script snippets but please let me know if you need more details.
Thanks in advance!
Nicole_Ueberschär
Update: I changed Step4 using new variable names for the list and its items. Now it works. Can someone maybe explain to me why I can't use the same loop/variables?
    list_of_campaigns = FindFiles(location_for_tables)
    for each_campaign in list_of_campaigns:
        arcpy.AddMessage(list_of_campaigns)
DanPatterson_Retired
Find_files function may hold the key, is it a generator expression or something? It sounds like the values needed to be reset
Nicole_Ueberschär
Thanks for your time Dan.
It is a function:
def FindFiles(location):
    arcpy.env.workspace = location
    listingFiles=arcpy.ListFiles("*.txt")
    return listingFiles
maybe the return value makes it get blocked somehow?
JoshuaBixby
MVP Esteemed Contributor
Without knowing what your other custom functions are doing, exactly, it is hard to say why.
