Creating a conditional statement
1390
08-22-2017 02:57 PM
CaseyRagain
Hello, I'm having trouble with how to write a 'relevant' conditional statement based the answers to previous fields. Here is some background information.
I have 5 fields:
  • NEEDED, type - select_one, choices - yes or no
  • CORNER_TYPE, type - select_one, choices - CD, IT, D, ID, CS, I
  • RAMP1
  • RAMP2
  • RAMP3
My conditional statement is:
When the field Needed is Yes, ramp fields are enabled/disabled based on the Corner_Type:
  • If Corner_Type is CD (Continuous Double) or ID (Island Double), Ramp1 and Ramp2 fields are enabled.
  • If Corner_Type is D (Diagonal) then only Ramp1 is enabled.
  • If Corner_Type is IT (Island Triple) or I (Incomplete) then all ramps are enabled.
  • If Corner_Type is CS (Continuous Single) then all ramps are enabled
Is it possible to write out all of the above scenarios in just one function?
Thank you in advance.
Casey
Tags (1)
RalphBeishline
Can you confirm that bullet point three and four are both meant to say 'enabled'?
If so, I'd try this and see if it works as you need.
namerelevant
RAMP1${NEEDED}='yes'
RAMP2${NEEDED}='yes' and ${CORNER_TYPE}!='D'
RAMP3
${NEEDED}='yes' and ${CORNER_TYPE}!='D' and ${CORNER_TYPE}!='CD'
If bullet three or four is meant to disable all RAMPs, just add another ${CORNER_TYPE}!=
JamesTedrick
Esri Esteemed Contributor
Small modification - RAMP3 also needs
and ${CORNER_TYPE}!= 'ID'
RAMP3 could also be expressed by the valid values (as there are 3 valid values and 3 invalid values); this is the pattern I would use if the number of invalid values is larger than the number of valid values:
${NEEDED}='yes' and (${CORNER_TYPE}='IT' or ${CORNER_TYPE}='CS' or ${CORNER_TYPE}='I')
deleted-user-qzyyiYme1rz9
James's reply is one way to do it. Here is another approach. Both should work for you.
