Printing from PDF issue ?
2274
08-22-2017 09:17 AM
DEAF_PROBERT_68
Honored Contributor
I have been having an issues with the PDF when I exported from ArcMap.  In ArcMap, I set up the layout as 34 x 24 landscape.
But when I export it to PDF and wanted to print to 11 x 17. It seems like when it prints the image is offset on the paper or sometimes it would print to 8.5 x 11 . Has anyone ever had that problem ?
I have ArcGIS 10.3.1
Adobe Acrobat Pro DC
Question : So when you first open the PDF and go to the File -> Print  settings
Here is what I have here .  The Actual Size should be set to 17 x 11 but it showing as  it is 8.5 x 11 (purple square color). If I change it to Fit , it will fit the document but why does it set to 8.5 x 11 instead of 17 x 11 ?
Does anyone have any suggest as why it does this way ? Is it my ArcGIS 10.3.1 not up to with the Adobe Acrobat Pro DC ?
This is driving my crazy !
DanPatterson_Retired
it is probably the default setting for the printer or for acrobat
DEAF_PROBERT_68
Honored Contributor
Yes, it is what it looks like. My IT Specialist is looking into getting me a new driver for this to see it works.
