Need help putting latitude and longitude CSV excel file onto map
3461
9
08-16-2017 02:54 AM
BenProsser
Firstly, I'm new so i can't do much. I have a small amount of data, each linked to a lat/long destination. However whenever I try to import this, it says:
'Longitude, and / or Latitude, not fully specified".
I was wondering if someone could tell me how I'm meant to lay it out so that it is fully specified?
Thanks.#
NeilAyres
Can you post a view of your Lat/Long values here?
BenProsser
NeilAyres
So which is the Lat & Long columns?
I would suggest you need a header line.
NeilAyres
Ah, is that ...
a string with both coords in the same cell?
That's not going to work.
I think you need to re-arrange this data. With 2 columns, one each for the Lat & Long.
And you data items as columns as well, not rows as you have it here.
BenProsser
Ah okay, thanks!
BenProsser
Is this better?
NeilAyres
You will have to split that first column into 2 columns. But that would be the way to go.
DanPatterson_Retired
You need to rearrange your table
Longitude, Latitude, Open_space, Age, Noise, Upkeep, Cleanl, Pedest
            -51       51.                     2        2       -3             0          2          27
Notice, that everything is a number, the first row is the header, there are no blank rows AND, the field names are short, don't begin with a number, and have NO spaces (and don't contain reserved words)
BenProsser
Thanks!
