Measurement Widget: disable tooltips & units
2395
08-14-2017 12:02 PM
AndreiLuca
Is it possible to disable the icons tooltips in the Measurement Widget sandbox ?
And also disable certain units of measurement that are not necessary for a user?
Thank you,
Andrei
Tags (1)
RobertScheitlin__GISP
Andrei,
   Sure here is a sample for both of those:
<!DOCTYPE html>
<html>
  <head>
    <title>Measure Tool</title>
    <link rel="stylesheet" href="https://js.arcgis.com/3.21/esri/themes/calcite/dijit/calcite.css">
    <link rel="stylesheet" href="https://js.arcgis.com/3.21/esri/themes/calcite/esri/esri.css">
    <style>
      html,body {
        height:100%;
        width:100%;
        margin:0;
      body {
        background-color:#FFF;
        overflow:hidden;
        font-family:"Trebuchet MS";
      #map {
        border:solid 2px #808775;
        -moz-border-radius:4px;
        -webkit-border-radius:4px;
        border-radius:4px;
        margin:5px;
        padding:0px;
      #titlePane{
        width:280px;
      </style>
      <script src="https://js.arcgis.com/3.21/"></script>
    <script>
    var map;
    require([
        "dojo/dom",
        "esri/Color",
        "dojo/keys",
        "dojo/parser",
        "dojo/query",
        "esri/config",
        "esri/sniff",
        "esri/map",
        "esri/SnappingManager",
        "esri/dijit/Measurement",
        "esri/layers/FeatureLayer",
        "esri/renderers/SimpleRenderer",
        "esri/tasks/GeometryService",
        "esri/symbols/SimpleLineSymbol",
        "esri/symbols/SimpleFillSymbol",
        "esri/dijit/Scalebar",
        "dijit/layout/BorderContainer",
        "dijit/layout/ContentPane",
        "dijit/TitlePane",
        "dijit/form/CheckBox",
        "dojo/domReady!"
      ], function(
        dom, Color, keys, parser, query,
        esriConfig, has, Map, SnappingManager, Measurement, FeatureLayer, SimpleRenderer, GeometryService, SimpleLineSymbol, SimpleFillSymbol
        parser.parse();
        //This sample may require a proxy page to handle communications with the ArcGIS Server services. You will need to
        //replace the url below with the location of a proxy on your machine. See the 'Using the proxy page' help topic
        //for details on setting up a proxy page.
        esriConfig.defaults.io.proxyUrl = "/proxy/";
        esriConfig.defaults.io.alwaysUseProxy = false;
        //This service is for development and testing purposes only. We recommend that you create your own geometry service for use within your applications
        esriConfig.defaults.geometryService = new GeometryService("https://utility.arcgisonline.com/ArcGIS/rest/services/Geometry/GeometryServer");
        map = new Map("map", {
          basemap: "satellite",
          center: [-85.743, 38.256],
          zoom: 17
        var sfs = new SimpleFillSymbol(
          "solid",
          new SimpleLineSymbol("solid", new Color([195, 176, 23]), 2),
          null
        var parcelsLayer = new FeatureLayer("https://sampleserver1.arcgisonline.com/ArcGIS/rest/services/Louisville/LOJIC_LandRecords_Louisville/...", {
          mode: FeatureLayer.MODE_ONDEMAND,
          outFields: ["*"]
        parcelsLayer.setRenderer(new SimpleRenderer(sfs));
        map.addLayers([parcelsLayer]);
        //dojo.keys.copyKey maps to CTRL on windows and Cmd on Mac., but has wrong code for Chrome on Mac
        var snapManager = map.enableSnapping({
          snapKey: has("mac") ? keys.META : keys.CTRL
        var layerInfos = [{
          layer: parcelsLayer
        snapManager.setLayerInfos(layerInfos);
        var measurement = new Measurement({
          map: map
        }, dom.byId("measurementDiv"));
        measurement.startup();
//remove tooltips
        query(".esriMeasurement .dijitButtonContents").forEach(function(node){
          node.title = "";
//adjust distince units drop down list
        measurement._distanceUnitStrings = ["Miles", "Kilometers", "Meters"];
        measurement._distanceUnitStringsLong = ["esriMiles", "esriKilometers", "esriMeters"];
    </script>
  </head>
  <body class="calcite">
    <div id="mainWindow" data-dojo-type="dijit/layout/BorderContainer" data-dojo-props="design:'headline',gutters:false"
    style="width:100%; height:100%;">
      <div id="map" data-dojo-type="dijit/layout/ContentPane" data-dojo-props="region:'center'">
        <div style="position:absolute; right:20px; top:10px; z-Index:999;">
          <div id="titlePane" data-dojo-type="dijit/TitlePane" data-dojo-props="title:'Measurement', closable:false">
            <div id="measurementDiv"></div>
            <span style="font-size:smaller;padding:5px 5px;">Press <b>CTRL</b> to enable snapping.</span>
          </div>
        </div>
      </div>
    </div>
  </body>
</html>‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍
Andrei,
<!DOCTYPE html>
<html>
  <head>
    <style>
      html,body {
        height:100%;
        width:100%;
        margin:0;
      body {
        overflow:hidden;
      #map {
        border-radius:4px;
        margin:5px;
        padding:0px;
      #titlePane{
        width:280px;
      </style>
    <script>
    var map;
    require([
        "dojo/dom",
        "esri/Color",
        "dojo/keys",
        "dojo/parser",
        "dojo/query",
        "esri/config",
        "esri/sniff",
        "esri/map",
        "dijit/TitlePane",
        "dojo/domReady!"
      ], function(
        parser.parse();
          zoom: 17
          "solid",
          null
          outFields: ["*"]
        var layerInfos = [{
          layer: parcelsLayer
          map: map
//remove tooltips
          node.title = "";
    </script>
  </head>
          </div>
        </div>
      </div>
    </div>
  </body>
AndreiLuca
Working great, thank you Robert !
