Use Survey123 with feature service. allow barcode functionality
1385
08-11-2017 02:30 PM
AhnaMiller2
I have been looking at this link to create Survey123 surveys from an existing feature service Use Survey123 with existing feature services—Survey123 for ArcGIS | ArcGIS
What I would like to do is use the Survey123 barcode feature to populate a field in my feature service. I cannot figure how I should configure the field in the database to all me to scan information into it from a barcode using survey123.
Any thoughts?
AdrianWelsh
MVP Honored Contributor
Ahna,
This would work better if placed in the Survey123 for ArcGIS‌ group instead of the GeoNet Help.
Does this blog post help?
https://community.esri.com/groups/survey123/blog/2016/05/17/understanding-barcode-questions-in-surve...
AhnaMiller2
Thanks Adrian, I'll try going through Survery123 group instead. And thank you for the blog post, I have already looked through that resource to no avail. I'll see if I can find answers elsewhere
JamesTedrick
Esri Esteemed Contributor
Hi Anna,
 Barcode question will be a text/string type of field
