Widget to widget communication.
924
08-08-2017 04:32 AM
Raghunatha_ReddySura
I have widget A. I am publishing data from widget A, to widget B (onreceivedata) . Now, When I have done with the widget B, I want to send the data  back to widget A, that was already open.
How to call onreceivedata in widget A, that was already open.....
RobertScheitlin__GISP
All you need to do is use the publishData method in Widget B and if widget A is already open then the onrecievedata method will be invoked.
Thanks for your reply. Will it work for in panel widgets also?
Yes
