Enable DataInteroperability in ArcGIS Pro
4968
08-07-2017 01:24 PM
BraulioGalvez1
Hi Community!.
I'm wirting, because i need your help or feedback about this item. I installed ArcGIS Pro 2.0 and Data Interoperability (The same version), then licensed both platform and other additional extensions. The licensing used was single Use. (Physicall).
On Pro, I saw the tool Workbech of DataInterop, showed disabled. I thought was the licensing used, but no because, i changed the license to User named and concurrent use and the status of disabled don't change.
Can you help me please? I don't the manner of enable DataInterop in Pro 2.0.
I hope your commnets,
Regards.
Braulio.
BraulioGalvez1
Yes! that was where I starded. the print screen is of Concurrent License (Borrow), but I tested with the license single use and User named.
I think just need reinstall DataInterop newly.
Thank you Dan.
BraulioGalvez1
Just was reinstall DataInteroperability. The problem was fixed!
Thank you!
