Is it possible to open an existing survey with a URL?
1825
08-04-2017 12:58 PM
MikeOnzay
I have a scenario where one person would start a survey and then sometime later a different person would complete the survey. Rather than having the second person search through the survey123 inbox on their device I would like to send them a hyperlink that would open the correct survey.
I guess I'm asking if their is a custom URL that has a query capability on it.
JamesTedrick
Esri Esteemed Contributor
Hi Mike,
Survey123 doesn't yet have a URL parameter to indicate that it is to open up an existing record for editing.  I've added this request to the issue for bringing in this support.
KevinProst1
Still no way to do this? I have a similar scenario where I would like to recall an existing survey to do a repeat inspection on a construction site.
Ideally I would like to include a URL in the polygon feature that is created on the geoshape polygon item to recall the very same survey.
 James TedrickIsmael Chivite
JamesTedrick
Hi Kevin,
This is an area the Survey123 team is currently working on.  You can expect to find some documentation soon in the Survey123 Early Adopter Community to begin trialing the experience.
