No ArcSDE server license found - Separate SDE install on ArcGIS Server 9.3.1
2061
01-12-2011 01:50 PM
MichaelOllom
Receiving the following error below when trying to initialize a service on our ArcGIS Server.  The install and setup for SDE on our Oracle server from this GIS server worked without issue.  The ArcGIS Server is Enterprise Advanced with SDE so that's not the issue.  I've also recreated the service a few times to confirm that I didn't input the wrong sde password or something.
Any ideas?
ArcSDE 9.3.1  for Oracle10g Build 1632 Thu Feb 26 12:05:37  2009
ST_Geometry Schema Owner: (SDE) Type Release: 1007
Instance initialized for ((sde)) . . .
Connected to instance . . .
WARNING: SDETMP: Setting temp path to c:\temp
DBMS Connection established...
Error (-327), No ArcSDE server license found.
VinceAngelo
Esri Esteemed Contributor
Does the query "SELECT char_prop_value FROM sde.server_config WHERE prop_name = 'AUTH_KEY'"
return any rows in the instance? (If so, please don't give it here.)
If not, and either a custom setup GUI to authorize the database or manual 'sdesetup -o update_key
-d ORACLE10G -l {path_to_saved.ecp} -u sde -p {password}' doesn't install the license, please contact
Tech Support for assistance.
- V
