Use python to zoom on opening
1678
07-28-2017 12:13 PM
CarlRoss2
how can i use python to ..upon opening a map,center (pan/zoom) to an event ( a point drawn by a X Y Coord. in a table kept in the map) and set the extent of that in data view to 1:10000?
Tags (1)
DanPatterson_Retired
If everything is already in the project at the desired location and scale... save it as a bookmark... then save the project.
When the project opens, everything will be as you left it.
However, I suspect that what you really want is a script that takes user input for some point coordinate, then zooms to that location and scale... that is a separate beast.
MicahBabinski
You could try an application extension, which as I understand it will listen for events like opening an MXD and then execute some logic, which could include what you mentioned.
Creating a Python add-in application extension—Help | ArcGIS for Desktop
To zoom to your feature, select it using Select By Attribute and then use the zoomToSelectedFeatures method of the data frame object.
DataFrame—Help | ArcGIS for Desktop
Good luck.
Micah
