ArcMap Animation
1364
07-27-2017 03:25 PM
PinelopiTrapezanlidou
Hello!
I have 30 rasters showing the slope for 30 years and I am trying to create a time series animation by using animation tool. However I am trying to find a way for each year to be appeared during the animation. I can't enable the time of the layers (there is no "time" option in properties) and subsequently I can not enable the time slider. Is there anything else I could try for having the time step included in the animation? Thank you in advance.
XanderBakker
Esri Esteemed Contributor
I think the best way to do this is to create a Mosaic Raster Dataset and add a field with a date (or two field with from and to date) and then you can enable time on your Mosaic Raster Dataset.
I tried to create a mosaic dataset and then to add my rasters to this mosaic dataset without success since I receive the error "ERROR 999999" "No mosaic dataset item selected".
XanderBakker
Can you share how you created your mosaic raster dataset (what configuration parameters did you use)?
