Registering view with SDE using command line
2240
07-26-2017 04:02 PM
deleted-user-BW4gdg3wFVuo
I am trying to run the command line to register a view with SDE, something like this:'sdelayer -o register -l'. I am using ArcGIS 10.3.1 and get the error "sdelayer is not recognized as an internal or external command. I read on some other forums that this method is no longer valid past 10.2. Is there another method?
Robb
Tags (1)
Asrujit_SenGupta
Starting from 10.3, the SDE Command line tools were deprecated.
Esri introduced the capability to Register Views with Geodatabase using GP Tools at 10.5. Take a look at the below links:
https://community.esri.com/groups/geodatabase/blog/2016/12/14/new-at-105-registering-a-database-view...
Register a table or view with the geodatabase—ArcGIS Help | ArcGIS Desktop
Thank you, much appreciated!
