List view custom widget for web app builder
6798
11
07-24-2017 09:35 AM
NiloufarHosseini_Pour
list view custom widget
Create a ListView widget—Web AppBuilder for ArcGIS (Developer Edition) | ArcGIS for Developers
has a bug in the code. I think the problem is at step 8 and 9. since layerInfosObj is undefined.  and there is a problem in settings. Would you please provide me with the final working code?
Thank you very much.
KenBuja
MVP Esteemed Contributor
What is the list of modules in the define and the list of arguments in the function from step 6? Do their orders match?
The abc’s of AMD | ArcGIS Blog
niloufarhosseini_pour1
I copied as the instruction:
define([ 'dojo/_base/declare',
'jimu/BaseWidgetSetting',
'dojo/_base/lang',
'dojo/_base/array',
'dijit/_WidgetsInTemplateMixin',
'dijit/form/Select',
'jimu/LayerInfos/LayerInfos' ],
function(declare, BaseWidgetSetting, lang, array, _WidgetsInTemplateMixin, Select, LayerInfos) {
but I get an error mentioning layerInfosObj  is undefined.
RickeyFight
I have yet to be able to get their sample code to work.
RobertScheitlin__GISP
All,
   Here are my fixes commented in the code for this sample:
jsong-esristaff
Settings.js:
// Copyright © 2014 - 2016 Esri. All Rights Reserved.
// Licensed under the Apache License Version 2.0 (the "License");
// you may not use this file except in compliance with the License.
// You may obtain a copy of the License at
//    http://www.apache.org/licenses/LICENSE-2.0
// Unless required by applicable law or agreed to in writing, software
// distributed under the License is distributed on an "AS IS" BASIS,
// WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied.
// See the License for the specific language governing permissions and
// limitations under the License.
define([
    'dojo/_base/lang',
    'dojo/_base/array',
//Fix 1 add ', _WidgetsInTemplateMixin' to the declare array
    return declare([BaseWidgetSetting, _WidgetsInTemplateMixin], {
      baseClass: 'jimu-widget-listview-setting',
      postCreate: function() {
        //the config object is passed in
        this.setConfig(this.config);
      setConfig: function(config) {
        // Update header text
        this.headerTextNode.value = config.widgetHeaderText;
        // Get all feature layers from the map
        var layerInfosObj = LayerInfos.getInstanceSync();
        var infos = layerInfosObj.getLayerInfoArray();
        var options = [];
        array.forEach(infos, function(info) {
          if(info.originOperLayer.layerType === 'ArcGISFeatureLayer') {
            options.push({
              label: info.title,
              value: info.id
        this.layerSelect.set('options', options);
//Fix 2
        if(config.layerId){
          this.layerSelect.set('value', config.layerId);
//End Fix 2
        this.layerSelect.on('change', lang.hitch(this, function(value) {
          var selectedLayer = layerInfosObj.getLayerInfoById(value);
          if(selectedLayer) {
            var fieldOptions = array.map(selectedLayer.layerObject.fields, function(field) {
              return {
                label: field.alias || field.name,
                value: field.name
            this.thumbnailSelect.set('options', fieldOptions);
            this.titleSelect.set('options', fieldOptions);
//Fix 3
            if(config.thumbnailField){
              this.thumbnailSelect.set('value', config.thumbnailField);
            if(config.titleField){
              this.titleSelect.set('value', config.titleField);
//End Fix 3
      getConfig: function() {
        //WAB will get config object through this method
        return {
//Fix 4
          widgetHeaderText: this.headerTextNode.value,
//End Fix 4
          layerId: this.layerSelect.get('value'),
          thumbnailField: this.thumbnailSelect.get('value'),
          titleField: this.titleSelect.get('value')
Widget.js:
define(['dojo/_base/declare',
    'jimu/BaseWidget',
    'dojo/_base/lang',
    'dojo/Deferred',
    'dgrid/OnDemandList',
    'dgrid/Selection',
    "dojo/store/Memory",
    "esri/tasks/query",
    "esri/symbols/SimpleMarkerSymbol",
    "esri/symbols/SimpleLineSymbol",
    "esri/symbols/SimpleFillSymbol"
  function(declare, BaseWidget,
    lang, Deferred,
    OnDemandList, Selection, Memory,
    Query, SimpleMarkerSymbol, SimpleLineSymbol, SimpleFillSymbol) {
    //To create a widget, you need to derive from BaseWidget.
    return declare([BaseWidget], {
      baseClass: 'jimu-widget-listview',
        this.inherited(arguments);
        this.headerNode.innerHTML = this.config.widgetHeaderText;
        this.featureLayer = this.map.getLayer(this.config.layerId);
        var highlightSymbol;
        switch(this.featureLayer.geometryType) {
          case 'esriGeometryPoint':
            highlightSymbol = new SimpleMarkerSymbol(SimpleMarkerSymbol.STYLE_CIRCLE, 20, null, '#e74c3c');
            break;
          case 'esriGeometryPolyline':
            highlightSymbol = new SimpleLineSymbol(SimpleLineSymbol.STYLE_SOLID, '#e74c3c', 3);
            break;
          case 'esriGeometryPolygon':
            highlightSymbol = new SimpleFillSymbol(SimpleFillSymbol.STYLE_SOLID,
              new SimpleLineSymbol(SimpleLineSymbol.STYLE_SOLID, '#fff', 2),
              '#e74c3c');
            break;
        this.featureLayer.setSelectionSymbol(highlightSymbol);
        this.createList();
      getDataStore: function() {
        var def = new Deferred();
        var layer = this.map.getLayer(this.config.layerId);
        // Query features
        var query = new Query();
        query.returnGeometry = false;
        query.outFields = ["*"];
        query.where = '1=1';
        layer.queryFeatures(query, lang.hitch(this, function(featureSet) {
          var featureSetRemapped = [];
          for(var index in featureSet.features) {
            var feature = featureSet.features[index];
            featureSetRemapped.push({
              'id': feature.attributes[this.featureLayer.objectIdField],
              'title': feature.attributes[this.config.titleField],
              'thumbnailImg': feature.attributes[this.config.thumbnailField]
          def.resolve(new Memory({
            data: featureSetRemapped
        return def;
      createList: function() {
        this.getDataStore().then(lang.hitch(this, function(datastore) {
          var list = new(declare([OnDemandList, Selection]))({
            'store': datastore,
            'selectionMode': 'single',
            'renderRow': lang.hitch(this, function(object, options) {
              return this._createListItem(object);
          }, this.ListNode);
          list.startup();
          list.on('.dgrid-row:click', lang.hitch(this, function(evt) {
            var row = list.row(evt);
            query.objectIds = [row.data.id];
//Fix 1
            this.featureLayer.selectFeatures(query, esri.layers.FeatureLayer.SELECTION_NEW, lang.hitch(this, function(result) {
//End Fix 1
              if(result.length) {
                var feature = result[0],
                  newMapCenter,
                  geometry = feature.geometry,
                  extent = geometry.getExtent(),
                  shape = feature.getShape();
                if(extent && extent.getCenter) {
                  newMapCenter = extent.getCenter(); // polygon & polyline
                } else {
                  newMapCenter = geometry; // point
                this.map.centerAt(newMapCenter); // move to the feature
                if(shape) shape.moveToFront(); // move the feature to front
      _createListItem: function(featureObj) {
        var listItemRoot = document.createElement('DIV');
        listItemRoot.className = 'list-item';
        if(featureObj) {
          var thumbnailImgWrapper, thumbnailImg, listItemTitle;
          // Create thumbnail
          if(featureObj.thumbnailImg) {
            thumbnailImgWrapper = document.createElement('div');
            thumbnailImgWrapper.className = 'thumbnail-wrapper';
            thumbnailImg = document.createElement('img');
            thumbnailImg.src = featureObj.thumbnailImg;
            thumbnailImgWrapper.appendChild(thumbnailImg);
            listItemRoot.appendChild(thumbnailImgWrapper);
          // Create title
          if(featureObj.title && typeof featureObj.title === 'string') {
            listItemTitle = document.createElement('H4');
            listItemTitle.innerHTML = featureObj.title;
            listItemRoot.appendChild(listItemTitle);
            if(thumbnailImg)
              thumbnailImg.alt = featureObj.title;
        } else {
          listItemRoot.innerHTML = 'NO DATA AVAILABLE';
        return listItemRoot;
Jianxia
Robert,
Thanks for the fixes. We will look into it. cc to YMa-esristaff
Jianxia
RickeyFight
Even with Roberts fixes I cannot get this widget to work.
Rickey,
   Strange I have no problem (after my changes). You may want to carefully re-check each step of the tutorial.
RickeyFight
Robert,
I will delete everything and start over and see if I can get it right.
Update:
I got it working. Thank you Robert Scheitlin, GISP‌
BTW, you cannot just copy and paste in your code. The ending parentheses and brackets in widget.js can be confusing.
suggestion:
more code or ...
Rickey,
  Strange I thought I copied the complete Widget.js code when I posted it. I will have to check that but it should have just copied and pasted.
