SearchCursor - RuntimeError: cannot open - Feature Class
13205
6
07-23-2017 06:26 PM
BWSCIM
I'm attempting to read a specific field from a Feature Class using the following code (search cursor):
import arcpy
import os
arcpy.env.workspace = 'C:\Users\jas\Documents\ArcGIS\L_Sr_geodatabase.gdb'
#inputFeatures = arcpy.GetParameterAsText(0)
inFeatures = 'LF_Stormdrains'
fc = os.path.join(arcpy.env.workspace,inFeatures)
# check if exist
if arcpy.Exists(fc):
   print "Feature Class Exists"
# check name
fc_list = arcpy.ListFeatureClasses()
for fcname in fc_list:
    arcpy.AddMessage(fcname)
fields = ['ASSET_ID']
if arcpy.Exists(inFeatures):
     arcpy.AddMessage("Feature Class Exists...")
with arcpy.da.SearchCursor(fc, fields) as cursor:
     try:
          if cursor.next() != ():
               cursor.reset()
               for row in cursor:
                    assetID = row[0]
                    arcpy.AddMessage(assetID)
     except StopIteration:
          print('Empty Cursor')
I'm stumped on the RuntimeError: cannot open 'feature class'.  Any help would be appreciated!
MitchHolley1
What exactly are you trying to accomplish with the Search Cursor?
Don't forget to add an 'r' in front of your database path.
#No :(
#Yes :)
arcpy.env.workspace = r'C:\Users\jas\Documents\ArcGIS\L_Sr_geodatabase.gdb'
BWSCIM
Thanks Mitch, I'll try this. Ultimately I'm trying to do some relational queries between feature classes based on an Asset_ID.
Additionally, Ive noticed that as I change feature classes it will run the first time, then provide the same runtime error when I try and run the script again.  Am I not releasing the cursor properly?
MitchHolley1
Yeah, I've never seen a cursor like that before.  Please check this link on SearchCursor.  You don't necessarily have to set an arcpy.env.workspace either.
It should look similar to this:
database = r'C:\pathtoDatabase.gdb'
fc = database + '/' + 'fc'
fields = ['AssetID']
    for row in cursor:
        assetID = str(row[0])
        arcpy.AddMessage(assedID)
del cursor
AlexanderBrown5
Mitch gives a great example above -- it is really important to close your cursor:
del cursor
If you do not, then you will have a persistent lock on the data.
RichardDaniels
MVP Regular Contributor
Nice of ESRI included this gem in their examples 🙂
BruceHarold
Esri Frequent Contributor
Hi, on the off chance your 'relational queries' involve set comparison this might be useful:
https://pm.maps.arcgis.com/home/item.html?id=e638afe0695a4ad38388cb8d9b350446
