Publishing Error: xform2webform
3761
7
07-21-2017 02:44 PM
KevinPrickett
I am receiving the following error when trying to publish a survey in Survey123
Publishing error code: 401  Error transferring https://survey123.arcgis.com/api/beta/xform2webform - server replied: Internal Server Error
Survey123 Connect Version: 2.3.24
Any help is greatly appreciated!
JamesTedrick
Esri Esteemed Contributor
Hi Kevin,
Does you survey have external selects?
KevinPrickett
The survey does not have any external selects. The survey only has internal cascading selects.
JamesTedrick
Okay.  We're seeing the error you are reporting with external selects and have identified a fix that we're working on implementing right now.  I just tried a basic cascading select example and am not getting that error.  Can you share your XLS Form?
KevinPrickett
I've attached the xls form.
JamesTedrick
The issue is the pulldata('@geopoint') function - we got a bit ahead of ourselves (since the new web form doesn't support that part of the pulldata function, we set an error if it found it, though it's causing issues in Connect, as you have found out).  We're working to resolve this.
KevinPrickett
Thanks for helping me to understand the problem. Looking forward to your suggested resolution.
BradenBurkholder
