Attribute Table not showing layer data in when I open Edit Web Mapping Application Edit or View Web Mapping Application, but does load when I open the Web Map Viewer.
3884
7
07-21-2017 06:47 AM
MaryGambordella
The map in question can be found HERE
I have a Web Map with two services in it. One is called the CS Interactive Map and has 14 layers, the other is called the CS Basemap and has 8 layers. The basemap is used as just that, a basemap (though not selected to be a basemap, the Topographic basemap is used). Both of these items hold a layer called Streets (in the CS Basemap it is divided into Major Roads and Streets). The CS Interactive Map Streets layer is configured to show a pop-up and has a custom attribute display. The CS Basemap Streets layer (both Major Roads and Streets) has the pop-up turned off, and is set to display a list of field attributes.
When I open the Web Map in the Web Map Viewer, if I click "Show Table" on the CS Interactive Map, I can see the attribute table exactly as it should be. This goes for the Major Roads and Streets layers in the CS Basemap as well. When I go to the Web Mapping Application and click Edit Application, if I open the Attribute Table widget, the CS Interactive Map Streets layer is turned on, and the CS Basemap Streets (Major Roads and Streets) layer is turned on. If I click Open Attribute Table and select the CS Basemap Streets (both Major Roads and Streets), they both load and show all the correct data. If I select the CS Interactive Map Streets layer nothing shows. There is no loading icon (like I see for the Basemap for a split second before the data appears) and no attribute data shows at all. The same situation occurs when I select View Application for the Web Mapping Application.
I am stuck at what to do next. I did try changing the display option for the CS Interactive Map Streets layer from a Custom Attribute Display to display a List of Attributes, but the data still did not show. Any help would be appreciated.
KellyHutchins
Esri Notable Contributor
Looks like this is a question about the attribute table widget in the https://community.esri.com/community/gis/web-gis/web-appbuilder?sr=search&searchId=84f41f9f-9c0d-4c8...
MaryGambordella
So can I not post it here, or do I need to repost it completely in that other section?
KellyHutchins
You can leave it here - I tagged it so it should show up on the activity feed for that space.
MaryGambordella
Thank you
RobertScheitlin__GISP
Mary,
  Are there any error shown in your browsers web console (developer tools F12)?
MaryGambordella
No.
Then your best bet is to call esri tech support. Without any error it is not possible to provide any help based on your description.
