Only return fields with values in webmap popup (not null)
2563
07-18-2017 03:51 PM
AdamVellutini
Hello.  Has anyone discovered a way to return only the fields that have a real value (not null) in a webmap popup?  I know there is not a setting or configuration in either ArcGIS Online or Portal that allows it.  I am wondering if anyone has found a way to customize a popup for this purpose.  Or, has possibly created a widget that does this?  I am working with a feature layer with over 100 fields and in most cases only 15--20 are populated.  It would be great if users didn't have to scroll through the entire list of fields to see what amenities are present at each location.
Thanks!
Adam
RogerF
I have done that in Popup Panel Widget
Popup Panel Widget Version 2.4 - 03/28/17
You can then modify displayPopUpContent method in widget.js file to filter null attributes.
AdamVellutini
Thank you for the response.  I downloaded and tested the widget; very nice!  Unfortunately I don't have a ton of experience with javascript.  That said, I will see what I can find about filtering out null attributes.  If you have any additional information you'd like to share about that it would be greatly appreciated.  Thanks again for the response.
Adam
James_001
Adam,
In the popup panel in Web map try the Custom  option where you can edit your own expression. Try that!
IIf ( condition , trueValue , falseValue ) returns  { * }
