ArcGIS Cloud Builder Managed DB: What & Where is it?
1399
07-12-2017 06:41 AM
ZacharyHart
Honored Contributor
I recently created a single machine deployment using ArcGIS Enterprise Cloud Builder 10.5.1 for Azure and have a few questions I can't seem to find answers to. We have an ArcGIS Enterprise 10.5.1 license. (ArcGIS for Server Enterprise Standard).
  1. Does the Cloud Builder designate a Hosting Server by default?
  2. What & where is the managed DB? It's already registered in the Data Store. The Cloud Builder didn't create any instance of SQL (no RDBMS)  that I can find. Does ESRI leverage a different technology for a Managed DB?
  3. Cloud Builder did not create an enterprise GDB anywhere that I can see. Since we do want to create an Enterprise GDB, do we then have to manually spin-up another VM hosting an (in this case) SQL Server instance, create an Enterprise GDB on that instance, and then register that with the data store? If so, why isn't this part of the default deployment process? In order to do this, i'm going to have to get ArcGIS installed on a VM up in Azure just so I can have the tools to create the Enterprise GDB.
RandallWilliams
Hi Zach,
Enterprise Cloud Builder installs and registers ArcGIS Data Store as the managed database.
ZacharyHart
Honored Contributor
Randall, thanks. I actually found another thread that went into depth on this. I was ready to call the relational data store a hoax or misnomer, but apparently there is Postgres under the hood somewhere.
I also learned that 10.5.1 is going to be the last version you can register an enterprise GDB as your site's managed DB for a hosting server! That's pretty insightful right there....
