Get height from tin at specific coordinate(s)
3468
5
07-10-2017 02:05 AM
RehmSoftware
I need to get the height from a tin for a given point (or a sequence of points) using the ArcGis Pro SDK.
I successfully created a tin layer with the 3D Analyst Tool "Create Tin" and it looks very good in ArcGis Pro. But now I wonder how it's possible to actually get a height value from this layer? I'm aware of "Intersect3DLineWithSurface_3d" but that seems like overkill and I'd prefer to do it in plain code instead of calling a python function.
Also: Extracting the polygons from the tin via the "TIN Triangle" tool gave me the tin as polygons and I tried to intersect a polygon with a polyline representing a vertical ray.. but I had no success in obtaining the height.
Any help would be greatly appreciated. Thanks!
Best Regards,
Christian
by Anonymous User
Not applicable
I'm guessing Charlie meant to say look at GetZsFromSurfaceAsync Method
ClaytonCrawford
Sorry, there isn't a TIN specific API call in Pro to do this yet. Therefore, calling a GP tool is probably the way to go. Instead of Intersect3DLineWithSurface look at InterpolateShape, which will produce 3D points from your 2D query locations, or AddSurfacceInformation, which will add a height attribute to your 2D query point features.
We are evaluating TIN API requirements and are seeking input. Aside from spot height query, do you have other needs from a TIN API?
Regards, Clayton
CharlesMacleod
Sent from my iPhone
by Anonymous User
Not applicable
RehmSoftware
Hi Sean,
thank you, that's what I was looking for!
Best Regards,
Christian
RehmSoftware
Hi Clayton,
thank you as well for your suggestions. The InterpolateShape_3d tool did work as well but I prefer to do it via the GetZsFromSurfaceAsync-method. Maybe I need to get accustomed to using tools in my c# code first, it doesn't really feel natural to me so far.
Apart from querying the tin for heights at specific coordinates there's not really much I need in a tin API to be honest. Especially since there are already tools like "Decimate Nodes" when working with a tin
Best Regards,
Christian
