SimpleFillSymbol
3528
6
07-07-2017 05:33 AM
TomNicoski
SimpleFillSymbol no longer works with version 4.4
RobertScheitlin__GISP
Tom,
   This sample and several others shows it working just fine:
https://developers.arcgis.com/javascript/latest/sample-code/sandbox/index.html?sample=visualization-...
TomNicoski
Robert,
Thanks for your reply.  The only way I am able to get it to work is to change the version back to 4.3 from 4.4.  The following is how I am using.
I am actually defining a symbol_pin
 //Parcel Outline Symbol.....
      var symbol_pin = new SimpleFillSymbol({
        color: "white",
        style: "none",
        outline: {
        color: [0,0,255,0.8],
         width: 4
Then use with my search widget
 resultSymbol: symbol_pin,
Tom....
Tom,
  Can you provide a full sample of code that does not work?
Tom,
   OK I have thrown together a sample to demo the bug you are seeing:
<!DOCTYPE html>
<html>
<head>
  <meta charset="utf-8">
  <meta name="viewport" content="initial-scale=1,maximum-scale=1,user-scalable=no">
  <title>Search widget with multiple sources - 4.4</title>
  <style>
    html,
    body,
    #viewDiv {
      padding: 0;
      margin: 0;
      height: 100%;
      width: 100%;
  </style>
  <link rel="stylesheet" href="https://js.arcgis.com/4.4/esri/css/main.css">
  <script src="https://js.arcgis.com/4.4/"></script>
  <script>
    require([
      "esri/Map",
      "esri/views/MapView",
      "esri/widgets/Search",
      "esri/layers/FeatureLayer",
      "esri/symbols/PictureMarkerSymbol",
      "esri/symbols/SimpleFillSymbol",
      "dojo/domReady!"
    ], function(
      Map,
      MapView,
      Search, FeatureLayer, PictureMarkerSymbol, SimpleFillSymbol) {
      var map = new Map({
        basemap: "dark-gray"
      var view = new MapView({
        container: "viewDiv",
        map: map,
        center: [-116.5453, 33.8303], // lon, lat
        scale: 10000000
        color: "white",
        style: "none",
        outline: {
          color: [0, 0, 255, 0.8],
          width: 4
      var searchWidget = new Search({
        view: view,
        allPlaceholder: "Palm Springs Neighborhood",
        sources: [{
          featureLayer: new FeatureLayer({
            url: "https://services.arcgis.com/V6ZHFr6zdgNZuVG0/ArcGIS/rest/services/Palm_Springs_Neighborhoods/Feature...",
            popupTemplate: { // autocasts as new popupTemplate()
              title: "Name {NAME} </br>{CONTACT}, {EMAIL}",
              overwriteActions: true
          searchFields: ["NAME"],
          displayField: "NAME",
          exactMatch: false,
          outFields: ["*"],
          placeholder: "example: Mountain Gate",
      // Add the search widget to the top left corner of the view
      view.ui.add(searchWidget, {
        position: "top-right"
  </script>
</head>
<body>
  <div id="viewDiv"></div>
</body>
</html>
Here is the error in the console:
MapView.js:511 Uncaught TypeError: Cannot read property 'setTransform' of undefined
at Object.n [as drawPoint] (MapView.js:511)
at e.doRender (MapView.js:503)
at e.b.processRender (MapView.js:293)
at b.renderChild (MapView.js:500)
at b.e.renderChildren (MapView.js:290)
at b.e.doRender (MapView.js:286)
at b.processRender (MapView.js:293)
at n.renderChild (MapView.js:427)
at n.e.renderChildren (MapView.js:290)
at n.e.doRender (MapView.js:286)
You should call tech support and file this bug.
ubatsukh-esristaff
TSolow-esristaff
ThomasSolow
Seems like this may be a search widget issue rather than a SFS issue.  I can remove any reference to the SFS and I get the same error: JS Bin - Collaborative JavaScript Debugging
Edit: my new best guess is that this is a view.graphics issue.
UndralBatsukh
Hi there,
Thank your for reporting this behavior. I was able to confirm it is an issue related to Search widget when polygon and polyline features are returned as a search result.  I created an issue for it.
