Pro 2.0 crashes when accessing unregistered view in SQL GDB
1085
07-06-2017 08:29 AM
ThomasColson
Is this supposed to be the default behavior? A SQL 2014 ENT GDB, version 10.3.1, a view that IS NOT registered with the DB, works fine in ArcMap and GIS SVR (also 10.3.1). When I right click on the view in Pro 2.0 Catalog thingy, and select Properties, Pro crashes. This happens every time. Are unregistered views blocked now?
Tags (3)
JakeSkinner
Esri Esteemed Contributor
Hi Thomas,
I would try to reproduce this with another view.  If it still crashes, I recommend logging a case with Tech Support so they can log this bug.  Once the bug is logged, it can then be addressed by developers.
MichaelVolz
Thomas:
Would you know if this Pro behavior also occurs against an unregistered view from an Oracle DB?
ThomasColson
I only have SQL.
