Opening widget from another widget programatically
1106
07-03-2017 04:52 PM
bobpark
I have been working on a project to generate report for few weeks now, and I encountered some problem when I am opening widget from another widget programmatically.
The code I used is this,
var generateReportWidget = this.appConfig.getConfigElementsByName('GenerateReport');
var widgetId = generateReportWidget[0].id;
this.openWidgetById(widgetId);
I got this code from widget Sample folder(widget to widget communication).
I works great but when I open widgetA from widgetB programmatically, then if I open widgetB, the tab is blank.
here is the before and after screenshot of the widget.
    before                                           after
Thank you.
RobertScheitlin__GISP
Bob,
what do you mean by "then if I open widgetB"? Programmatically or from the widget link?
