WAB Vector tile layers
2847
07-01-2017 11:16 AM
nspittlemeister_LCFPD
In the June 2017 release of ArcGIS Online, Web AppBuilder was listed as now being able to consume Vector Tile Layers in the Basemap Widget. I have tried to add a vector tile layer that I published from ArcGIS Pro to WAB online version and get an error (see image below). Has anyone gotten this to work successfully with a vector tile layer created in Pro? I am currently running ArcGIS Pro 1.4.
Thank you,
Nick
WAB Vector Tile Layer Basemap Error
I contacted ESRI tech support and they have logged this issue as a bug.
I received the following response in regards to the bug.
The status of Esri BUG-000106317 - When adding Vector Tile Basemap in Web AppBuilder Basemap Widget an error "This type of layer cannot be used as a basemap." will appear. - that you have been associated with has been changed to Not in Current Product Plan.
Public Explanation: At this time the only supported vector basemaps in the WAB basemap widget are the Esri default basemaps.  If using a custom basemap it must be a raster, not vector, basemap.
BledarBirbo1
Hi Nick.
Have you managed to configure the Web AppBuilder to work with ESRI Vector Basemaps ?
