How to remove undrawn/unavailable layer from webmap?
1534
07-03-2017 02:46 PM
EmilyLee2
Hello GeoNet,
It might be an easy question, but I can't seem to find the answer for it... I have this map service (Cities) that is currently not available, but I don't know how to remove it because it's not visible on the webmap.  If I just click OK, the error message would come out every time I load the webapp.  Is there a back-end way to remove the layer altogether?  So, I don't need to rebuild another webmap without the unavailable layer?
Thank you!
Emily
JayantaPoddar
After opening the web map, save it again. Open the web map again.
Does the issue persist?
Think Location
JayantaPoddar
Think Location
EmilyLee2
Wow, just like that?!  Thank you, Jayanta!! 😃  You're right. The unavailable layer is no longer in the layer list under the webmap's detail page.  😃  Thank you!
