Cannot overwriteOutput with arcpy.da.NumPyArrayToFeatureClass
1212
07-02-2017 09:30 AM
OliverDaniel
When I try to run NumPyArrayToFeatureClass from both and ArcGIS Pro interactive session (built in python console) or from a script, it does not let me overwrite output despite setting the env.overwriteOutput variable to True
>>> arcpy.env.overwriteOutput = True
>>> arcpy.da.NumPyArrayToFeatureClass(arr,fc,['xy'],sr)
File "<pyshell#28>", line 1, in <module>
RuntimeError: table 'C:\Users\olive\OneDrive\Documents\ArcGIS\Projects\MyProject\MyProject.gdb\charlie' Exists
DanPatterson_Retired
That is because you can't... check the warning in the help topic same in arcmap or in Pro
