Labeling expression with python scripts
2718
5
06-27-2017 01:11 PM
nimitz
Hi all,
I have a geodb file that has a field for pole numbers. I'm trying to label only poles, but the field also has some manhole numbers and pull box numbers - I don't want to label those. The pole numbers always begin with a "PP", so an example is like "PP6042". Whereas a manhole would beging "MH" and pulbox "PM". How can I only label poles with the PP? It seems like this would be straightforward, but I'm drawing a blank on this.
Thx for any help,
Tags (3)
JakeSkinner
Esri Esteemed Contributor
Hi Randy,
Below is an example.  'Label' is the field name.
JakeSkinner
Hi Randy,
nimitz
The error, "Error 1 on line11, Expected 'Then'.
I tried to place "then" on a new line and the same line, but the exact error comes up.
JakeSkinner
Make sure you have 'Python' set as the parser.  Also, can you upload a screen shot?
nimitz
I'm sorry, I had checked the "VBSCRIPT" dropdown by accident. I have since changed it to Python and it works beautifully!
nimitz
You 'da man!
