ntext from SQL view, ArcMap read it as blob instead Text
1621
06-16-2017 12:01 PM
DiegoLlamas
In my SQL server database I have a field called observaciones_hechos(ntext,null).
  in SQL appear as text
I am creating a view from this database table in ArcMap and for some reason instead seeing the text in the table of content I just see blob
How can I see the text instead blob in the view? Can I do that?
Diego Llamas
JoshuaBixby
MVP Esteemed Contributor
ntext is a legacy data type that has been deprecated:  ntext, text, and image (Transact-SQL) | Microsoft Docs
Fixed and variable-length data types for storing large non-Unicode and Unicode character and binary data. Unicode data uses the UNICODE UCS-2 character set.
IMPORTANT!ntext, text, and image data types will be removed in a future version of SQL Server. Avoid using these data types in new development work, and plan to modify applications that currently use them. Use nvarchar(max), varchar(max), and varbinary(max)instead.
ntext isn't listed as supported in ArcGIS:  SQL Server data types supported in ArcGIS—Help | ArcGIS Desktop
Looking back through documentation, it appears ntext hasn't been supported since ArcGIS 9.2 or 9.3.1.
