Arcgis for Server - Activation code
1418
06-16-2017 06:39 AM
João_PauloMoura
Hi guys. I'm trying to install ArcGis for Server 10.3.1 with an activation code for 10.5 version but it doesn't work. Is there any problem using this activation code for a prior version of Arcgis for Server?
Thank you
Tags (1)
RebeccaStrauch__GISP
10.5 does have a different code than 10.0-10.4, so you will not be able to use the same code.  If you have been on maintenance for a while (pre 10.5), you should be able to go to you myesri page to get that license instead of the 10.5, assuming you only have one license.
if this is a new purchase since 10.5 was released, you may need to talk to your customer service rep or local distributor to see if you can use previous version. I am not sure how the licensing works in that case, but they may be able to help.
João_PauloMoura
 Thank you very much!
RandallWilliams
That's correct. Esri rekeyed licenses at 10.5. I believe you can license with a 10.1-10.4 license, then restart the GIS Server. Then you can create the site.
João_PauloMoura
