Problem in Popup with URL without HTTP/HTTPS
3587
06-14-2017 02:20 AM
FlavieMORAUX1
I encounter a problem in Popup (WebMap and WebApp) with URL whitout HTTP/HTTPS.
  • Link is not clickable
  • Link is wrong (prefixed with webmap/webapp URL)
Problem depend of popup display mode:
  • Mode "List of field attributes"
Display Mode "A list of field attributes"
==>Link is not clickable
  • Mode "Custom attribute display"
Display mode "Custom attribute display"
==> Link is wrong (prefixed with webmap/webapp URL), so it does not work
From WebMap URL is prefixed with « http://capgeo.maps.arcgis.com/home».
From WebApp URL is prefixed with « http://capgeo.maps.arcgis.com/apps» .
My questions :
  • Do URLs have to be prefixed with HTTP¨/HTTPS?
  • Behavior difference between two mode (List/custom) is normal?
Thanks for your advices,
Flavie
FC_Basson
The short answer is yes.  HTTP(S) prefixes are required to generate automatic hyperlinks in the popup.
See this page https://blogs.esri.com/esri/arcgis/2016/08/24/url-parameters-in-pop-ups/  and Supported HTML—ArcGIS Online Help | ArcGIS
FC_Basson
FlavieMORAUX1
Thank you!
And from my side I also found reference of similar problem : BUG-000096662 : A CSV with attribute that contains URL values set as hyperlink in ArcGIS Online pop-ups fails to redirect to the right page if it does not contain "HTTP://".
So the only solution for me is :
  • Have URL with HTTP/HTTPS protocol;
  • Or use custom Popup and Prefix URL with HTTP/HTTPS
Flavie
ChristineSharp
We have a linked field in a configured popup for a portal map which opens the website in that field.  THe issue is, not all of the website entries have the 'http://" added to the beginning.  How do I find the values without "http://" and then add it in the link so all the website values will work?  I have tried using IIF function in the arcade expression window, but cannot find the correct way to use a 'LIKE' statement with a wildcard.
I am not terribly familiar with the Arcade syntax and have not been able to find examples to learn how to set this up - any ideas?
