ArcMap modify gdb and update layers in TOC
2630
7
06-12-2017 10:07 AM
by Anonymous User
Not applicable
I created multiple maps using the data stored in one geodatabase (all layers pointing this geodatabase).  I modified geodatabase layers' alias, but layers in TOC weren't updated.  I prefer not to recreate maps by adding layers again and setting the definition query and symbology and so on.
Q.  Is there a way to update layers' alias in TOC in ArcMap without re-adding the layers to the map?
Thank you in advance.
Tags (1)
AdrianWelsh
MVP Honored Contributor
Makiko,
This is a great question. It might be best to have this question in the https://community.esri.com/community/gis/managing-data?sr=search&searchId=df3ab0eb-520a-4459-a846-84...‌ space. The GeoNet Help is for help with the GeoNet.
DanPatterson_Retired
moved to Managing Data‌
GeoNet Community Structure for your info
JoshuaBixby
MVP Esteemed Contributor
Make a backup of the MXD, just in case, but I think the following will work for you (from the interactive Python window in ArcMap):
>>> mxd = arcpy.mapping.MapDocument("CURRENT")
>>> lyrs = arcpy.mapping.ListLayers(mxd)
>>> for lyr in lyrs:
...     try:
...         desc = arcpy.Describe(lyr.dataSource)
...         lyr.name = desc.aliasName
...     except NameError:
...         pass
>>> arcpy.RefreshActiveView()
by Anonymous User
Not applicable
Hi Adrian and Dan,
I was having difficulty to find the correct place to ask a question.  Thank you for moving my question in right place.
Hi Joshua,
Thank you so much for your reply and Python code.  I am wondering that if it can be done without Python.  I thought layer update can be done easily such as clearing database cache and refreshing the TOC.  I couldn't find a way to do it in ArcMap.
I will keep open my question since I am curious if there is a way to do it in ArcMap.  Meanwhile, Python is the best option so I will use it for my work.
Thank you!
JoshuaBixby
I updated the code to trap and dismiss errors for layers that don't have a dataSource property, like group layers.
Unfortunately, I am pretty sure the way to do it in ArcMap is the same process the Python snippet uses, i.e., visit each layer and update the name.  I may be wrong, maybe someone will share a slicker way to do it.
If clearing the database cache and refreshing the TOC worked, it would cause all sort of problems for users.  What if a DBA changed an alias for a feature class and a user didn't want the layer to be automatically renamed in their TOC?  I think most users would not want their TOC changing if a database cache was cleared.
by Anonymous User
Not applicable
Thank you, Joshua.
You are correct. Some users want to create their own alias in their maps, so changing a layer instance alias in ArcMap works for them well. As you mentioned, it is a huge problem if the layer alias is renamed automatically. On the other hand, for some users (like my organization) the database is the primary source, meaning all instances of layers that consume data from certain database in ArcMap need to be updated when the database is modified. This is the reason why I am interested in whether there is a way to manually (or otherwise) change an ArcMap setting, but it seems it is a good idea to create a Python scripting tool for this so I can share the tool with my colleague.
Again, thank you so much for your response!!
AdrianWelsh
Makiko,
Like Joshua said, it looks like Python uses the same process you would have to take but makes it more automatic. I would suggest using that method with the Python snippet provided. It seems like it would be even less steps to use this Python snippet than to go through with clearing a database cache and refreshing the TOC (and of course the issue Joshua brought up with what could happen with clearing the cache, etc.).
