ArcMap Query Layer results do not match ArcSDE Table or SMSS SDE Table View
1740
06-13-2017 08:36 AM
RachelAlbritton
I am working in a versioned database (SQL Server 2012, ArcMap 10.4). When I view the table in ArcMap or Catalog I see 17 rows of data. When I create a query layer based on this table, it returns 15 rows of data AND the data that it returns is old data. Specifically, its returning 1 row of data that has been removed, and is not returning 3 new rows of data that have been created. The table with the correct data is the same database and version that I am creating the query layers against.
Correct Data: Connected to the database with transaction version 'Edits'
Incorrect Data and Inputs:
Connected to the same database inwhich the properties of that DB are set to point to the 'Edits' version.
NOTE: I have also done the query so that the table name is appended with the view (uusd.dbo.das_antenna_info_evw) and I get the same results. I have also tried creating the query layer by going to File > Add Data > Add Query Layer
If I go into SMSS and query the table view (table_name_evw) I get the correct records back, but if I query table directly I get the incorrect results - the results that I'm getting back with the query layer
Whats going on here?
Asrujit_SenGupta
When you are using Versioned Data, query the Versioned Views for the latest records.
The Base\Business Tables will not have all the recent edits unless you have perform a Compress. The compress moves the recent edits from the Delta Tables (a- & d- Tables) into the Base table.
What is a versioned view?—Help | ArcGIS Desktop
When you query a versioned view, you can see the data in the base (business) table and the edits that are stored in the delta tables.
RachelAlbritton
Thanks Asrujit - but I was querying the versioned view. Yet the query layer was still creating a layer based on the base table. I've figured out that if I unregister the table as versioned it works but that's starting to creating some other issues when viewing data on AGOL. I'm still problem solving that part of it.
