When I try to edit a hosted feature layer, the edit does not stick?
2298
5
06-12-2017 07:40 AM
DianaHackenburg
When I try to edit an attribute of a hosted feature layer feature, the cells revert to the original content. The edits don't seem to "save." I have editing enabled, so why can't I edit the layer?
PanGIS
Hi Diana,
are you the publisher?
check the settings of your hosted layer, maybe some settings doesn't allow you to edit.
DianaHackenburg
Yes, I am the publisher. Not sure what settings could prevent editing since I enabled editing.
CarmelConnolly
Hi Diana,
What browser are you using? How was this hosted feature layer added to ArcGIS Online?
Carmel
MaryEllen_Perko
Hi.  Did you ever figure this out?  We are experiencing the same problem.  We are editing a hosted feature layer through AGOL's web map viewer.  Editing is enabled with defaults except "only update feature attributes" is selected.
Thanks.
KellyGerrow
Esri Alum
Try monitoring the edit request with a web debugging tool. Is there a specific error message that indicates why the edit isn't being posted?
https://community.esri.com/groups/cats/blog/2017/05/04/monitoring-web-service-requests-from-web-apps...
-Kelly
