Set the proprety "MaxFeatures" of QueryParameters catch a exception
1594
06-12-2017 12:30 AM
xiaoguangyan
When I set QueryParameters.MaxFeatures then execute ServiceFeatureTable.QueryFeaturesAsync(QueryParameters parameters, QueryFeatureFields queryFeatureFields) then will catch a exception(Unable to complete operation.), but don't set it codes go well, Anyone can help this? Thank in advance
Tags (1)
JenniferNery
When you create QueryParameter, do you set one of these properties: WhereClause, Geometry, ObjectIds? At least one of these is required by the service. Or do you only set MaxFeatures?
I'm not able to reproduce with the following code unless I remove setting of WhereClause, then I'll get this error as expected.
{"error":{"code":400,"message":"Unable to complete operation.","details":["Unable to perform query operation."]}}
        public MainWindow()
            InitializeComponent();
            MyMapView.Map = new Map(Basemap.CreateStreets());
            MyMapView.Map.OperationalLayers.Add(new FeatureLayer(new Uri("http://sampleserver6.arcgisonline.com/arcgis/rest/services/Census/MapServer/0")));
        private async void OnClick(object sender, RoutedEventArgs e)
            var table = (ServiceFeatureTable)((FeatureLayer)MyMapView.Map.OperationalLayers[0]).FeatureTable;
            var query = new QueryParameters() { WhereClause = "1=1" };
            query.MaxFeatures = 50;
            var results = await table.QueryFeaturesAsync(query, QueryFeatureFields.LoadAll);
xiaoguangyan
Hi Jennifer
I have set the WhereClause.
