Feature.SetAttributeValue() And Then UpdateFeatureAsync(Feature feature)
1796
06-09-2017 12:52 AM
xiaoguangyan
I got a exception "Internal error exception: *** has an incorrect value. Encountered on feature with ID of 4768"., when I use Feature.SetAttributeValue( "***", 2) And Then UpdateFeatureAsync(Feature feature), The Attribute I want to set is type of integer.
Tags (1)
NagmaYasmin
Hi Yan,
I happened to experience similar error while updating the attribute data of the field type "short" or "Int16" of a feature table to an integer like 2.
Numbers such as 2, 3 etc. are interpreted by the .NET compiler as type 'int' or 'Int32', so there is a mismatch of the field type. In this case the values must be explicitly declared as type 'short' or 'Int16'.
For your case, you may write the code as below:
Feature.SetAttributeValue( "***", (short)2);
Hope that helps.
Nagma
