That might be quite a challenge. Probably need to generalize the polygon features and select the remaining vertices based on a distance tolerance from the point and create the lines between vertices (excluding the diagonals) and split the geometry based on those new lines...
You placed this question in the ArcObjects SDK space, Just to be sure... is Python an option too? That would potentially save a lot of lines of code....
