10.2.1 Geocoding addresses with lot numbers
1050
05-17-2017 12:57 PM
by Anonymous User
Not applicable
In our county we have a lot of mobile home parks that have lot numbers at the end of the address (i.e. 123 Main St Lot 4).  We have an address point file that has this information in it but the lot number field is separate from the house number field.  I have been unable to create an address locator that can take into account the lot number field at the end of an address.  I've been using a Single House and tried putting the Lot field in Suffix Type but then no matches are found.  I tried putting the Lot field in the city field but then all addresses with same root address (123 Main St) have a 100% match rate.  I have heard that 10.3 can support addresses with units but the county has no plans to upgrade anytime soon.  I am using 10.2.1 with an Advance license (old ArcInfo level).  I have over 5,000 address at mobile home parks that I need to geocode.  Any suggestions would be great!
JoeBorgione
See if this thread is of any help to you:  https://community.esri.com/thread/26594   It has several versions of locators to download...
JoeBorgione
by Anonymous User
Not applicable
I checked it out and downloaded the locator styles.  I wasn't sure they would work since the thread was regarding version 10.0 and we are at 10.2.1.  Happy to report that they worked like a charm!  Solved my problem!  Thank you!
