How do you use SPK in hololens?
1451
05-14-2017 07:27 PM
xipeng
hello:
I want to use the SPK data captured by the drone in hololens
Does unity3D support SPK extensions?
I look forward to your reply
 thanks
xipeng
Thank you for your answer!
dotMorten_esri
Esri Notable Contributor
You will have to use Drone2Map to export the captured data to something that Unity supports (for instance FBX or OBJ).
Just beware that the drone-captured models gets quite complex for the HoloLens to render, so you might need to simplify your model so the HoloLens GPU can handle it.
xipeng
Mapbox has supported unity, and does arcgis consider supporting unity??
dotMorten_esri
It is something we are looking at. You can today use our Drone2Map and CityEngine applications to create 3D data that can be imported straight into Unity. You can also for instance in a Unity HoloLens app call straight into the UWP-version of the ArcGIS Runtime SDK for .NET to use various operations like data query, geocoding, route calculation etc.
Also check out this sample we shared here: https://github.com/Esri/hololens-terrain-viewer
xipeng
