Copy FGDB or Table from Shared drive
1555
05-15-2017 07:54 AM
by Anonymous User
Not applicable
Hello All,
I am trying to copy FGDB file which contains one table using python script
Source: Shared on shared drive which require userID and password
Destination : Again Shared drive which require userID and password
While i am connected the both shared drive folder on Arc Catalog tool works but without folder connection its not.
Can one have any solution which i can try  Please share to me.
1)How to open/connect shared drive which require credentials
2)how to copy file like filename_new and rename old one filename>>filename_old then again filename_new>> filename
With some validation will appreciated
by Anonymous User
Not applicable
Hello All,
I have found the solution and implemented using batch script,
Tasks:
Connect to both shared drive using net use and  use robocopy command to copy data from one server to an other.
Rename the previous data for back.
Read the log file and share on mail using SMTP python.
All done !
BlakeTerhune
What error message are you getting in Python? Can you post your code that constructs the file paths? How are you running this script, and with what user?
by Anonymous User
Not applicable
Hello All,
Tasks:
All done !
