pass value from another table in web map to survey123
1471
05-12-2017 07:55 AM
by Anonymous User
Not applicable
Hi all,
I have a feature and a related table. The related table is the one that the users will open to pass the data to survey123 but the data I want to pass in the feature layer. Would it be possible to pass some of the data from that feature layer to survey123 through my related table?
Alex
Tags (1)
JamesTedrick
Esri Esteemed Contributor
Hi Alex,
If I understand correctly, you want to prepopulate values in your survey form from the feature layer, correct?  This can be done by supplying a URL with the values - please see Integrate with other apps—Survey123 for ArcGIS | ArcGIS for more information.
by Anonymous User
Not applicable
Yes but the I want to pass the feature layer values from a different layer (related table).
JamesTedrick
Hi Alex,
I think this could still be done from the pop-up of the feature layer with the data you want.  There could be an issue if you are trying to place data from 2 different layers into the same URL.
